At IMTS 2024 in Booth 338129, MC Machinery will display its latest EDM and precision milling technology, including wire and sinker EDMs, machining centers and automation. Also featured will be the new Mitsubishi AZ600 wire-laser metal 3D printer, which melts welding wire with a laser beam to create high-quality 3D structures.
The International Manufacturing Technology Show (IMTS) will take place September 9-14 at McCormick Place in Chicago.
MC Machinery’s featured machines at IMTS 2024 will include:
Sinker EDMs
With artificial intelligence (AI) adaptive control technology, the Mitsubishi SV12P and SG28 sinker EDMs optimize performance, improve productivity, reduce electrical consumption and accurately estimate machining time.
The SVP Series features proprietary Mitsubishi technology that incorporates a state-of-the-art sensor to monitor the total amount of electrode contact area within the work piece, allowing the system to automatically change power conditions based on real-time measurement feedback. Along with producing the most efficient burn, this technology results in up to 40 percent less electrode wear and an up to 30-percent reduction in machining time.
At IMTS, the SV12P will be outfitted with Erowa Robot Compact 80 milling and sinker automation.
Also featured will be the OPS Ingersoll Gantry EAGLE 800 sinker EDM, which is especially geared toward large-part and molding applications. Along with low electrode wear and fast cycle times, the Gantry Eagle series has on-board components designed to reduce wear and tear, which in turn decreases maintenance and costly downtime. It also has a large, easy-to-access working area that requires less floor space than other sinker EDM models.
Wire EDMs
The MV1200-R Mitsubishi wire EDM features the latest machine construction, submerged threading, fiber optic machine communication and power supply technology. As MC Machinery’s best-selling wire EDM, the MV-R series is known to be dependable and easy to use, spurring increased productivity and efficiency. This machine will be shown with the Mitsubishi Electric six-axis robot automation system.
The MV2400-R Mitsubishi wire EDM is the perfect solution for a wide range of applications, featuring a larger tank capacity and low operational costs. The innovative MV-R series features improvements in machine construction, auto-threading, internal machine communication and power supply technology. It also highlights Mitsubishi’s dedication to high precision, with innovations including the highly dependable non-contact cylindrical drive system on the X, Y, U, and V axis drives.
The MV4800-S Mitsubishi wire EDM is ideal for large part applications up to 20-inches high (standard), and 32-inches high (optional) and can perform submerged cutting up to 20 inches deep. With an annealing length of over 27 inches, this system is capable of threading through the workpiece both at the start point and through the gap.
The MX600 Oil Advance Plus wire EDM combines the ultimate in machine accuracy and surface finish, with wire capability down to .0008″ (.02mm) Dia. The MX600 features a Nano-pulse power supply and DMX-S Super Digital Control sensor, specifically shaping each spark producing surface finishes down to 1.6µ “Ra. This machine provides the perfect opportunity to advance micro-machining capabilities.
The Roku HC658II is the gold standard for hard milling and electrode manufacturing. This machine is a full-bridge style design for supreme accuracy and each way surface is meticulously hand scraped. The highly dependable 32,000 rpm spindle, combined with the best graphite protection in the industry, makes the Roku HC658II the perfect solution for high-precision manufacturing and mold industry customers.
The ANDROID II linear drive milling machine is a machining center designed from the ground up for extremely precise, hard steel and carbide machining with accuracies within ±1µm. With a 60,000-RPM spindle, it boosts productivity on high-precision jobs, simultaneously delivering accuracy, quality, precision and speed
The Ingersoll Eagle V9C machining center performs high-speed, ultra-precision five-axis machining. With a temperature-controlled coolant system, the V9C is a flexible, functional and automation-ready machining solution.
Wire-Metal Laser 3D Printer
Using commercially available welding wire as the feedstock, the Mitsubishi AZ600 has applications including rapid prototyping, mold and die, one-offs, short runs, mass manufacturing, maintenance, repair, tooling, and more.
With the same proprietary wire-feeding technology used in Mitsubishi’s industry-leading wire EDMs, a simple command on the machine’s CNC control feeds the exact amount of wire to the target location. Unlike other 3D printers, the wire is in the front of the machine to make it easier to replace.
SV12P Sinker EDM
SV12P
Mitsubishi SG28 sinker EDM machine.
SG28
Gantry Eagle 800
Gantry Eagle 800
MV1200-R
MV4800-S Advance Type M800 Wire EDM
MV4800-S
MV2400-R
MV2400-R
MX600 Advance Plus Wire EDM
MX600
HC Series
Roku-Roku HC Series
Android super-precision machine by Roku Roku
Roku-Roku Android II
eagle v9c
Eagle V9C
AZ600 3D printer
